Johnnybravo
- Northiam
You have to grind the stakes out otherwise you deform the new cups pressing them back inUse a suitable small socket and a bigger socket, and a vice, to push one end cap through as far as you can, then it should be possible to wiggle it apart. Then repeat with the other side, then clean the bores up before plating and reassembly. I'd not bother grinding the staking dinks out as you are replacing the cup and centre section anyway.
