The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
Finaly.
A Signal Mans lantern.
Or a Wheel Tappers lantern.
I like mine, automaticaly adjusts when wifes on pillion or when I load up panniers, couple of clicks changes it from Auto to Soft for when I want more comfort. No more faffing about with C spanners...... its the futureI believe there is a way to disable the electronic suspension but would need a dealer to do it.
Can you post some before-and-afters please, once you've got it going? I have similar things (well, identical things) that need to be cleaned, and I'm considering how to approach the job.Got a pair of 48DHLA carbs to rebuild so hopefully this will help, 10L capacity so should be ideal if it works!
BUT does it still work?
i got some simlar glass pots in the cupboard! melba toast would be great with that but I am a heaven so reglar toast it is!I've just picked these up from a local person who didn't want them and listed them on a local Facebook "re-use, recycle" group.
I've checked and checked but please, if any of you know for certain that this is cat food (or any other "not suitable for human consumption" product) please shout before I get the crackers out.
Do they stop working? It's just a bar with a handle.BUT does it still work?
they wear out and dont sharpen anymore. I got loads of worn out ones they make good pokersDo they stop working? It's just a bar with a handle.
foie gras is greatGreasing the funnel before shoving it down a birds neck?
or is urs funnel shapedGreasing the funnel before shoving it down a birds neck?
Interesting. I've got an old one that's polished smooth, I prefer it to mum's one (Of a similar age and quality) thats pretty much never been used, hers "grabs" the blade a lot more and feels like its got to be doing more harm than good.they wear out and dont sharpen anymore. I got loads of worn out ones they make good pokers
they didnt use too!Do they stop working? It's just a bar with a handle.
old and smooth probably would not even tickle a newer knife edge, my old knifes were carbon steel so easy to keep sharpInteresting. I've got an old one that's polished smooth, I prefer it to mum's one (Of a similar age and quality) thats pretty much never been used, hers "grabs" the blade a lot more and feels like its got to be doing more harm than good.
no comment I aint going their!!!Well it’s not a blunderbuss if that’s what you are insinuating
Not as smooth as I remembered actually.they didnt use too!
things changed
knife metal became harder and er maybe more hygenic
the steels may have stayed the same but I expect they became softer then there are diamond steels these wear out so quickly with cheap modern hard steel knifes!
 that's the shed project funds depleted for a bit..
 that's the shed project funds depleted for a bit.. Also 80/100/120 pulley from Bearing Boys.
They'll be having their £500 back plus interest in that caseI believe there is a way to disable the electronic suspension but would need a dealer to do it.
