This rubble ramp is the beginning of my new yard surface,need MORE stone/rubble.ill then dress it down with scalpings.Its gonna cost!View attachment 344443
The clear pipe and similar size blast gates are from Axminster, the smaller outlets came from a nearby factory refit.Neat job. Where did you source the clear pipe and blast doors?
Can't remember the last time I used a hacksaw.I started on @s410man 's washer. I didnt have a suitable offcut, so it was a slice off the 2.5" bar. Small grinder doesnt have the reach, hacksaw practise...
View attachment 344495View attachment 344496
Bore and face done. This stuff turns nice. I didnt think the next bits through - I can grab the ID in my small 4 jaw, but theres no way to clock it in. I'll turn a 43mm mandrel and superglue it on instead.
Was that a kit or did you make the whole thing?So todays myself and @mtt.tr assembled my 1t hoist. Very pleased. Can lift 1t anywhere in my garage
View attachment 344477 View attachment 344478
As an apprentice I must have cut off literally thousands of foundation bolts with a hacksaw, usually laying on my side in a puddle of hydraulic oilCan't remember the last time I used a hacksaw.
Fair play.
.Was that a kit or did you make the whole thing?
Looks like the sort of thing I could do with. I like it because it low profile. I don’t have tons of headroom. About 10’
So was it built or bought?!It's bloody brilliant, I have a great level of envy![]()
I built it with another forum member. The garage was designed around the gantry. The two rails coming through the ceiling are bolted to four arches.Was that a kit or did you make the whole thing?
Cheers Kim. I’ll look forward to seeing thatI built it with another forum member. The garage was designed around the gantry. The two rails coming through the ceiling are bolted to four arches.
Then out of two bits of angle either side we made up trollies which hole the four wheels to run the length of the garage. That also fixes the two UC’s which allowed me to keep the hoist up high.
The hoist is mounted onto a trolly made from channel section, that had four bearings in each corner running across the top of the two UC’s. This obviously allowed for max head room. Whilst not losing any capability around the room.
I have been doing a video for this for the last couple months. I’ll try and get it out next weekend maybe. Still a load to finish.
I bet it doesn't.And the empty shelf it's created will help in decluttering the benches.
I'm sure everyone on here already knows this but I've found people that don't know that hacksaw blades come in different TPI, a 14 ( with cutting paste ) will make a big difference in effort on a big cutting job like that, probably save you half the time.I started on @s410man 's washer. I didnt have a suitable offcut, so it was a slice off the 2.5" bar. Small grinder doesnt have the reach, hacksaw practise...
| 14 | Large profiles, aluminium, softer metals |
| 18 | General workshop projects |
| 24 | Steel plate up to 5/6mm thickness |
| 32 | Hollow sections and steel tubing |
