Just ask @northwest to borrow the real thing for the weekend I'm sure he's got several
Just ask @northwest to borrow the real thing for the weekend I'm sure he's got several![]()
That's a crime against a perfect bit of engineering unchanged for over 100 years...sadly both are deactivated
Lots, in fact everything is standardIs there anything left on this ride that's factroy?
Simple channels of folded marine grade stainless steel having internal facing folded safety edges as strengthening & simple end stops .I've wasted some tig rods and solder paste.
It's a mock up of a spice rack, the plan was to make up two "sheets" like this, have them upright with some more rods to space them apart and the jars would fit in the hexagonal slots, probably with a third grid behind it to keep them falling out of the back.
This mockup has proven its a crap design. A square grid would give about 15 percent denser packing of the jars and would be much easier to make, I thought the hexagonal arrangement would look cool but now I've got it in front of me, I'm not that keen anyway.
If anyone's got any good ideas for spice storage I want to hear them. The main requirement is it has to be dense, I've got 53 jars (And counting) and a tiny kitchen.
Every time the rider put the lights on........ the battery exploded due to the dead short ?Ah yes. Dressed up.
I have heard of this term from the yanks.
Not really my cup of tea.
A folded channel would do if I had a folder, and some stainless.Simple channels of folded marine grade stainless steel having internal facing folded safety edges as strengthening & simple end stops .
Site them one above the other screwed to the walls or use super sticky double sided tape on highly volatile spirit cleaned surface to put them on the fridge door or inside cupboards on the doors . Make the channels just deep enough so you can read most of the labels & that they wont fly out if the door is close a bit quickly . Set the next row above it so you can easily remove a jar when needed
I was using tig rods because I already had it, and because the old rack was made of wire, but I do think it looks quite cool so I might stick with it. Stuck on the fridge door looks a bit ugly imo, same with using the kitchen door as someone said earlier (Plus it's a bifold). I did look at the inside of a cupboard door but it would take up a precious couple of inches at the front of the cupboard. I'll have another crack at it next time I feel the urge, for now I've put the 21 I use most back on the old rack and the rest are in a box in the hall and need tipping out on the floor to find the one I'm looking for.That's fantastic
The new saw in the mill has been in use for 2 days,today they crashed the de stoning cutter arm into the log and bent it,it’s a bit weak,a 60 mm shaft,only supported 1 side of the 100/40 box arm,I’ve suggested a reinforcement plate on the one side(it’s not possible on both sides),as I can see it happening again,problem is ,it deformed the box.
