jack-daniels
- England
Just to stop all the electrons from falling out.
If it's a metal case I'd check for earth continuity to the plug. I've seen a few shockers on Big Clives channelTreated myself to a new soldering iron that automatically cools down when the iron is in its stand
Came with a Chinese plug, no CE mark and there's a label on it saying "do not touch the device casing with wet hands", so I'm going to be a bit cautious around it, but it seems good so far: heats up from cold in a couple of seconds.
Yep, first thing I tried when I got it. To be honest I'm not sure what the case is. It looks like metal but it could be plastic made to look like metal. My guess is that it's anodised aluminium: there's no continuity from case to another bit of case, let alone conductivity to anywhere else like earth. Anodised aluminium is a fairly good insulator so it's plausible that it's that, but it might be plastic that's doing a very good impression of metal!If it's a metal case I'd check for earth continuity to the plug. I've seen a few shockers on Big Clives channel![]()
Needed a half decent set, picked up from Screwfix today, I'm impressed with the load and ejection system, nice solid quality. Will see if the cutters are good, got some 18mm steel I need to use them on.
Willco mate, at £84 I took a bit of a breath as well, but will hopefully see me through loads of jobs and although not the very best will be better than the garbage I have used before - I hope!Let us know how they fare. I've eyed the Bosch progressor holesaws up a few times, but could never decide whether they're worth a punt or not.
Any tips for cutting compound on cast steel?use cutting compound on them and keep the hole clear of swarf and they will cut it no probs. nice slow speed as well![]()
The drill bits are the only let down on those kits. I have one for work and found that oiut early on.Needed a half decent set, picked up from Screwfix today, I'm impressed with the load and ejection system, nice solid quality. Will see if the cutters are good, got some 18mm steel I need to use them on.
I notice "T245" on the display, does it take JBC cartridges?I'm impressed so far: I'm using it to make another cordless vacuum starter and that has some signal connections and also some gert big battery contacts that need 2 mm² (14 AWG) wire soldered on. Those battery contacts took a fair bit of time to solder with my old iron (or possibly my gas one: I can't remember what I used), but this one did it in no time. I also love how fast it heats up when you take the iron out of the stand:
The Vark could be a bit of an animalIn what way?
They loos the cutting edge very quickly.In what way?
No.The Vark could be a bit of an animal
I'm looking to pre pilot undersize due to the thickness and material of this job
It will be need constant peck drilling as holesaws have no clearance for chips. Would be much better off with a slugger type cutter... this sortI'm sorry to be a party pooper, but I really cannot see them cutting through 18mm steel.
Nothing todaySomeone elses post. If it were a one-off, fair enough.
I have told our postie repeatedly. A few days ago I caught him and gave the item back. His excuse is both streets are on the same round and he only looks at the numbersHow much post am I missing that the other house just bins? they were quite rude when it happened often, 10 years ago, and I delivered the post to them, asked if we had any.
I am expecting a tracked item that said it would be today, showed it as out flor delivery.. nothing. No sign of any postie, so I still have the wrong addressed post.
I stayed in waiting for both.
