Onoff
- Sevenoaks, UK
Can the pva stand molten wax at 70c? I would guess it will deform?
Damn, good point!
Im not sure what hes using as slurry
I bet that fish didn't come out in one piece!
I may be able to help with a programmable controller if you get to the point of needing one.At last, I now understand about the burn out process! Found this article, albeit for wax casting, that explains the cycles gone through.
Wax Casting Burnout Cycles - Ganoksin Jewelry Making Community
When casting, the burnout cycle is an important step that is often treated with indifference. Learn more about the lost wax casting burnout cycles.www.ganoksin.com
I've been touting round locally and even as far as Southend & Devon for brass casters and what they could offer as a quick service. No luck with what I want. Tbh I'm not really sure what I want, somebody to take our 3D printed models and do the investment then pour or we do the investment and give to them?
If we do the investment casting here then I think a vacuum chamber build is a must to get the air out. This investment powder I have here is supposedly air permeable hence suited to the vacuum process very well.
I think in reality I need to consider an electric furnace build. To then use as a burn out oven, my lad reckons he could use a Pi or similar to make a suitable, programmable controller instead of spending out £££ on a CAL 9500P.
On the look out for Grade 28 or similar fire bricks now.
@Kram , seriously, how are you fixed for doing this pour? Would the investment survive posting or would I need to careful transport it and drop it to you? On top of that is your furnace design good to go yet / something we could copy?
Cheers
.I think PLA is our best shot. If you send me a PLA print I'd firstly make up a sillicone mould and try wax, and then try burning out the PLA in plaster or sodium sillicate sand. I have some normal plaster to mix with sand or you could send a small amount, it wont need much.@Kram , seriously, how are you fixed for doing this pour? Would the investment survive posting or would I need to careful transport it and drop it to you?
Skip to 5 minutes.. and speed it up, lo g video but useful stuff. I guess lost foam is pretty similar to lost pla/wax in a shell.
@Kram@Onoff I have said I'd do it, infact I want to do it.
If you want I will make up a clay form* so you can have your own melter, and get the other bits sorted. You'll need a steel cylinder or similar, propane bottle. I have plenty of perlite etc..
* While my melter works I havent been in a rush to do version2. I am very happy the design is excellent. For an easier/quicker version you could buy a bag of dense castable refractory which would likely stand up much better than clay in terms of thermal shock/cracking. I'd still use perlite for the outer insulation, it is excellent stuff.
Controller, use a cheap rex-c100. There may be better ones but ignoring my calibration issue it works perfectly.
I think PLA is our best shot. If you send me a PLA print I'd firstly make up a silicone mould and try wax, and then try burning out the PLA in plaster or sodium sillicate sand. I have some normal plaster to mix with sand or you could send a small amount, it wont need much.
I could use one of those test print bits you sent to test with before hand.
I can have the melter running this week..
Im messing about with anodizing today so I can get the control box reassembled. The lid will be cherry red![]()
I havent tried it but I think its the right stuff. This lost foam guy made a similar style furnace using it. I remember they are quite helpful if you phone them - ask what its like for drying and cracking.@Kram this sort of castable refractory?
Dense Castable Refractory (25kg)
Castable refractory material suitable for those constructing ovens and for hot face lining in kilns and furnaces. We stock various grades of thiswww.castreekilns.co.uk
forums.thehomefoundry.org
There are many types of foam. Avoid any PU types as they will give off isocyantes and might have Mr Parm looking for you..High density foam gives off evil niffs when it's burnt, I think its was cyanide gas or something equally unpleasant. Something to consider when working in close confines.
Bob
Interesting but looks hard to get, expensive and possibly not suited to wrapping wires and lumpy connection welds.@Kram
May be of interest re. anodizing
Revolutionary Advances in Chromic Acid Anodizing Masking | CFS
Discover the latest innovations in chromic acid anodizing masking that improve precision, durability, and efficiency for high-quality metal finishing.www.customfabricate.com
@Onoff Making silicone moulds, skip firat min or two. I'll see if I can get some proper 2 part silicone.
