To be honest it gives us the chance to look for yin worm and clean out behind the wings, its amazing how much crud gets trapped.For some reason i thought it was a T4. LTs are easier but still awkward. Working through that hole in the doghouse is always fun. I never took the whole front off unless pulling the engine, but it does give you loads of room to work in.
Amazing how good these CR 2.5 5 cylinder engines are on fuel thou - I had one a SWB 08 plate crafter. Could never work out how it was so good on fuel and the gearing in the gearbox was so "short" - "low" in the lower gears - made a good tow vehicle thou.
My 2.5 Crafter drank like it was going out of fashion. 27 to the gallon at very best. My 2.1 Sprinter after that did 38-45. Current Sprinter with tow pack is shocking. 24 empty, 18-21 towing.
The SWB 08 plate 2.5 Crafter I had did 36-44 mpg (it was a 88bhp one - manual).
The MWB 11 plate 2.0 Crafter I got now does 24-29 mpg. 163bhp CKUB engine DSG gearbox (thirsty beast).
Have you seen the price of new VW Crafter van? Shocking!![]()
I was interested in doing the same on my 2.5 TDi T4 (ACV engine) but was told that the 5th gear cluster wasn't available for my engine/box. If you have information to the contrary I'd like to hear it...!The T4 i have seems amazing on fuel considering it is a 102hp 2.5, when i get time i am doing a lower 5th gear swap on it to see how much better it can be made.
I don't know if your software will allow it but you can get VCDS to cycle the turbo wastegate or vane system via the N75 valve at idle. This was my T5the N75 turbo control valve is still suspect but that is an easy swap, thanks all for input and interest.
That's rather odd. It was Dark Side that told me that there is no 5th gear upgrade available for my van... Perhaps I need to go back to them and see if things have changed on that front. It was 4 or 5 years ago that I asked the question.@mangocrazy The set up i looked at was a .622 5th gear from dark side developments it was around £250 when i started looking but has gone up a bit like most things, but it looks pretty easy to do.
https://www.darksidedevelopments.co...92-622-658-681-700-717-744-5th-gear-sets.html
5th Gear upgrade and more MPG's - VW T4 Blog
So now being a motor caravan and legally being able to travel at 70mph I often find myself sat between 55mph to 65mph on the motorway as doing long distance with the engine screaming can get a bit tedious. Ever since I upped the fuel and boost I have wanted to put a high ratio 5th gear […]www.t4blog.co.uk![]()
5th Gear Upgrade How To - VW T4 Blog
PLEASE NOTE THIS IS NOT MY CONTENT Original source Aggie on the T4Forum (link), I had noticed the images had not been working so wanted to archive these great instructions so they never disappear. You will need a 3 leg puller and similar 2 leg puller to remove the syncrohub from the mainshaft...www.t4blog.co.uk
dont think there is an upgrade for the 2.5 gearbox, its different to the 1.9 and 2.4'sThat's rather odd. It was Dark Side that told me that there is no 5th gear upgrade available for my van... Perhaps I need to go back to them and see if things have changed on that front. It was 4 or 5 years ago that I asked the question.
