when there was no ventilation the wet loose earth floor underneath never dried out and never caused a problem, as soon as airflow was introduced the humid air condensed under the beams and boards as it was warm above .i damp proofed the walls in the room that was a seperate issue and cleaned out the cavity as it was bridging up past the dpcThat's interesting and counter intuitive. Why do you think the beams sweated more with more ventilation? Warm, moist house air condensing on the cooler beams? Seems like the wrong direction of travel for warm air. What do you mean when you say you damproofed the room?
Ultimately, sounds like the solid floor was the way to go.
I'd like to replace a suspended floor with insulation, screed and maybe even UFH but it's ancient and built into the hill. So the wetness from the walls that are in places 3' underground needs to go somewhere.
glue remover
just scrape as much off as you can with a sharp wood chisel
if you was fitting plasterboard insulation it would cover it
You want one of theseHow do I get rid of the super glue residue and not damage the frame too much?
Yes. The rule of thumb with diagonal cracks is put a 90 square along the crack and the square points down to where the problem is (perpendicular to crack).That black drainpipe? I believe it goes to a soakaway next to the garage. I've never excavated or found it tbh. There is a pipe runs across that pokes through the ground but whether it's blocked etc I haven't a clue.
2 legged or fourLike putting a sticking plaster on a broken limb this is! Cold air is blowing through where the pen is pointing. No doubt it's coming from the cavity in part through imperfect mortar joints. No parge coat etc.
Reckon I'd be best pricing it all up and getting my mates down who'd offered to blitz it with me for a beery barbecue.
Anyway, that's enough for tonight, I've got to go photograph a cow.....
if your going to rip all that boading off then upgrade to the insulated stuff and leave it venting behind the woodLike putting a sticking plaster on a broken limb this is! Cold air is blowing through where the pen is pointing. No doubt it's coming from the cavity in part through imperfect mortar joints. No parge coat etc.
2 legged or four![]()
They are really really good at putting lots of little grooves, or lines, in plastic window frames, about the width of a razor blade . . .You want one of these
Razor Blade Scraper
Stanley Window Scraper
Heavy duty professional scraper for removal of paint, glue and debris. Brass push button with a retractable blade for safety in between periods of use.Includes rectangular blade (high carbon steel blade)Great for window cleaners, painters, decorators and DIY and enthusiasts alike. Sale will be...www.toolstation.com
Has the same around a doorframe of an internal cavity wall - it used to be an external wall, but the place was extended before it was first sold in the early 70's. Open under the floor, and at the top under the roof . . . if there was a good frost, or light snow, there was a nice clear stripe up each side of the roof . . . The wall was acting as a nice heat exhanger for the radiator mounted on it - warmed the air in it, it rose up out the top, thawing the roof, dragging more cold air in the bottom.Like putting a sticking plaster on a broken limb this is! Cold air is blowing through where the pen is pointing. No doubt it's coming from the cavity in part through imperfect mortar joints. No parge coat etc.
As proven on nearly every window in this hous
It's all 'in the way', you use your toolThey are really really good at putting lots of little grooves, or lines, in plastic window frames, about the width of a razor blade . . .
As proven on nearly every window in this house![]()
Sorry, but this isn't good advice. Insulated plasterboard can help add a useful extra layer of insulation on top of existing insulation but if you leave it venting behind it, it'll be essentially the ONLY layer of insulation, not to mention have naff all thermal mass. At 25, 50 or whatever mm of foam, that'll probably be an improvement on the current situation, but it shouldn't be the goal. Goal should be to get the inside skin sealed so that it, and whatever insulation in the cavity can start working, then add more insulation wherever most appropriate. In this case, my gut feeling would be blown EPS followed by ideall EWI or, potentially a careful layer of IWI.if your going to rip all that boading off then upgrade to the insulated stuff and leave it venting behind the wood
