MattF
- South Yorkshire
I just put "lots" in with a pick axe (a smaller "miners" pick, is better than a road mender's type: sharper so less dents)I've looked but are there any good guide on here as to how big / the best place to drill holes in a 45 gallon drum for use as a garden incinerator?
My old galv dustbin type has rotted out.
I read that in a book called " Scouting for Girls" My mates took the micky and said I should have read "Scouting for boys" But I told them i knew who I was scouting for .A bit like my apple tree above.
Pull some wispy bits of bark from that silver birch. It'll light even when wet. I was taught that when in cub scouts.
(Not "in" cub scouts... )
The lower vents on a log burner bring fresh air in and act like a Bunsen burner, creating a raging inferno so a few holes a few inches from the base to let air in to make the fire hot and a few holes in the base to let rain water out when you’re not using it and cover them with some large stones just like you would with a garden planter, for drainage without the contents falling out.I've looked but are there any good guide on here as to how big / the best place to drill holes in a 45 gallon drum for use as a garden incinerator?
First one I did I used a 20mm hole saw. Next was the same a small pick, far quicker and it works just as well.I just put "lots" in with a pick axe (a smaller "miners" pick, is better than a road mender's type: sharper so less dents)
the "bin" is just to hold the fuel. don't over think it. but stand it on bricks, and put some holes in the bottom for drainage: rain+ash rots out steel VERY quickly
Turf comes off really easily with a mini digger! Just another form of no dig by hand gardening!I'm tempted to just section off an area, maybe with a rabbit fence and just lay cardboard down on the grass and weeds. Tbh though 50% is covered with next door's rampant ivy.
I like more the turf off/clean slate idea.
Trench dug through the ivy covered top layer with 3' wide bucket. Down to the clay. Not quite 2' deep, 18" maybe and the length of the frame.
Bunged all the hedge and branch trimmings in and set fire to it. Nice bit of wood ash!
have you plans for the wood ash?
lye/caustic?
or just as soil additive?
"soil additive".Erm...I was just going to leave it in the bottom of the trench and mix it in as I put the soil back.
