Made up a little mold for casting aluminum bar billets, internal dims are 59.8mm x 80.8mm long but final piece will be 44mm od x 35mm long so allows for shrinkage and will be used as rollers for diy machine skates from 100*50 channel.
Bolt is flush with inside plate face so if the chunk of ali gets stuck I can remove the bolt then punch it out.
Skate model with a rotating foot on a needle roller thrust bearing version. Overall dims are roughly 100*100*65mm with a max load of 1000kg
) and that went okay I think just pouring into it should be fine for me
) so it can rest on Airy/Bessel points and keep the purists happy. Personally I don't think it matters, I briefly considered floating it in a pan of mercury to rub everyone up the wrong way, but I couldn't find a pan.
your talents are wasted it should be on etsy as a side table
