In fact we'll refresh this system by replacing the collector with pv shortly.
They're pretty trashed, the vacuum seal and outer is broke on a good half the tubes after all these years and I'm also fed up with persistent weeps from the flashing as the tubes pass out the roofspace. When we get them down off the roof probably there will be more issues because they've been left dry for a few years after I gave up on keeping it going.I read "free panels in France"!![]()
You've summed-up very clearly the problems from an end user experience. I've encountered several commercial installations where overheating has killed off all hope of reliability and energy saving. Fortunately, we just don't seem to have the solar thermal installations still being put forward. In the early days of PVs, there were problems with quality and particularly multiple panels being linked to one inverter but these have long been ironed-out.You will need some kind of mains power backup for summer to run all these pumps sensors etc. I have a large solar array (8m2) with these panels and a 1000L tank with multiple coils in it. In summer if you loose the power for 45 minutes in summer its enough to take the 1000L tank to boiling temperature and boil the fluid out the circulation circuit. We have a UPS capable of running the pumps for a hour, and after that its just a question of replacing failed components after the boil over (the safety valves we use dribble after they have released steam and need replacing each time), I've seen melted normal solder on joints too during this. Also be cautious where the valves point, the jet of steam will be impressive.
In winter it underperforms by far the predictions given to us by the solar design company. So it produces too much energy in summer when you don't need it, and in winter nowhere near enough. Also we're on the 3rd set of pumps in 12 years of operation, they wear and begin to stick occasionally at a certain age and that can be really bad. Also we had a commercial deltasol controller for the solar circuit control, and it has brain dead defaults. If its power cycled it forgets any bespoke settings and it defaults to disabling warming the panels in very cold temperature to avoid frost damage. So if it gets power cycled in winter, we have to go back in to the config and set it to enabled or risk frozen panels. I don't know if newer ones are any saner...
Another note on the tubes, they're fragile as someone already said. We lost the vacuum in quite a few due to hail stones and wind.
I would stump up the extra for the pv, solely on the basis that when it over-generates you don't have to get rid of the excess, and its not dangerous shooting boiling fluids or steam out if things fail. In fact we'll refresh this system by replacing the collector with pv shortly. And this is from having a similar set up running for 12 years. Right now its drained and the property vacant so I don't have to mess around trying to service it thankfully. If I sound bitter, that's because I am. We paid a lot of money to a professional company to spec and supply for our custom requirements, and I feel that it was a massive mistake.
It was to 100% cover DHW also, the 1000L storage tank has a on demand instant heat hot water heat exchanger for this tapped into the very top of the tank with its own pump triggered when you turn the hot taps on to run bath/shower/etc. So the hydronic solar was on its own sealed circuit on a coil in the tank. That's why we could control it to a degree sometimes by pouring gallons of steaming hot water out the taps down into the well on hot days but as we were on metered mains water supply as the well wasn't human consumption safe, this was a total (expensive) loss and I ended up adding a energy dump loop into the well with its own pump. Which is yet another pump circuit to control, maintain, frost protect with antifreeze levels, source of heat loss in winter, repair when it stuck on a hot day, have ups capacity to serve etc. It was permanently like walking a tightrope of disaster in summer.thanks for your input there jmp49
certainly reads as poorly engineered and certainly shouldnt have been specked for just heating the underfloor heating system
I built the house myself 35 years ago, sits on a decent plot, bought a tumbledown bungalow, lived in it for three years before building first the garage, then the house, then when I demolished the last of the old bungalow, the pool,You didn't say you was posh!![]()
Is the pool to be used as a pool again if it gets hot? Or is that not a priority? I guess a critical factor if it's just going to be a heat dump is how much energy it takes to maintain the heat each day. That'll give you a rough idea of how many kWh you've got to potentially limit panel production to with the blinds...?onoff has given permission for a hijack, similar problem and next to no idea how to do it.
I ended up with six flat plate solar panels, something like 6 feet by 4 feet each, Wolf, German, I also have some control gear and an expansion vessel but suspect that will be too small, had it for years, I have started converting the house to underfloor hot water heating, kitchen done, hall and study next, modern gas boiler, mains pressure hot water with a cylinder.
Original plan was to mount them on the back of the garage next to the house, now want to mount them as a car port behind the garage as a carport roof, less obtrusive and easier to maintain, south east facing, will get decent sun for a lot of the day.
I want to use the panels to heat our hot water and do a lot of the house heating............ I know, I know, but I do have a plan, I have an indoor swimming pool of a decent size that we (used) to heat from the gas boiler, too expensive to heat these days, so plan is to dump heat into the pool and draw it out when needed, the pool has a large mass of concrete around it and so only drops around 1 degree a day when we stop heating it.
As the solar panels will be low down I propose to install a wind out blind to shield the panels in the summer as a control method but as I said I know nothing...........
pictures to follow,
However, if you never wanted to swim in it again it could become an inter seasonal heat store!
In the pool room or house?Do you have good (read excellent) air tightness and an efficient, centralised, mechanical ventilation heat recovery system?
