Green so it doesn't burn too fast, but the idea is that the carbon in the end bit that gets hottest gobbles up the oxygen in the dross. Can accomplish the same with a cover flux but this can be as simple as crushed charcoal.Whats the willow stick for?
Nowhere near big enough for its secondary usageFinished cutting the tapered 6mm pitch buttress thread on the log splitter. I know where I would love to shove that, deep in the Ural Mountains
View attachment 335686 View attachment 335687 View attachment 335688
Lovely job thoughSalicylic acidWhats the willow stick for?
I tried, it didn't work.I wonder if you chucked a couple of disprin‘s in the crucible if that would work….
Think they contain that acid,but may be wrong ..
)Creepers ? What are they used for ?Finished off the slab yolks today, countersunk, bored and tapped for the clamping screws and then cut the slot in the bandsaw. Luckily I had the foresight to design the slot at 60 degrees to the base which made setting up in both the mill and bandsaw easy with a 90/60/30 set square (I hate I have to say that as it is obviously a triangle and not a square)
Also knocked up a set of creepers from an old 2" prop shaft and some 16mm round bar.
That is similar shape to what he has at the moment so obviously wanting a chunkier lookLike these? Cannot remember what they were for apart from it was some racebike
CreepingCreepers ? What are they used for ?
I hope he hasn't cocked up the offset!That is similar shape to what he has at the moment so obviously wanting a chunkier look![]()
And the angle between the stem and the fork legs .I hope he hasn't cocked up the offset!
and its really annoying me.
