Onthespotwelding
- Kent - England
I took the fuse out and stuck an old nail in thereGoing through a 13 amp fuse![]()
I took the fuse out and stuck an old nail in there![]()
You would have thought 2.5 and thats whats mine looks like but it's not marked on the cable but it is uk made cable. Borrowed from a friend ( not from toolstation) so i could see if it would do before i put in a dedicated 16a socket and mcb in the garage.Wonder if that artic cable is 1.5 or 2.5mm?
I want to fit a 16a socket in my garage too as it will also be better for my welder.You would have thought 2.5 and thats whats mine looks like but it's not marked on the cable but it is uk made cable. Borrowed from a friend ( not from toolstation) so i could see if it would do before i put in a dedicated 16a socket and mcb in the garage.
Toolstation have all the 16a connections that are required and cheap as chips and the cod.I want to fit a 16a socket in my garage too as it will also be better for my welder.
Slightly cheaper on amazon but I just bought the 13a plug and 16a socket for £5 from toolstation and used a scrap bit of wire I had.Plug connections sorted
Fly Lead Socket Convertor
Use this fly lead socket converter if you need to deliver power to an industrial plug but only have domestic sockets available. You'll find this useful while caravanning, camping and when using machines that have industrial-style plugs, like generators. There's a 13 A British Standard plug at...www.toolstation.com
TLC direct have all the gear/socket/trunking/4mm cable/new breaker etcToolstation have all the 16a connections that are required and cheap as chips and the cod.
I'm tempted if they have an impact wrench, did see an impact wrench and grinder combo for £60 on ebayJust a heads up - the lidl impact driver is due out soon. Whilst its not the most powerful, its £60 and I would not be without mine (I can't justify a more expensive one).
Here we go again
In bed for 8pm to be up for 5am to stand at the doors of the local store and try buy one of the 5 guns in the store. Think i will stay in bed
If you already have the batteries you would be better buying one of the Makita clones on ebay for £20-£30. I have one & its really surprised me of its abilities!
