The email address will be inside the 10 plasma cutter boxes around the country...good luck finding the addressI've tried several email addresses and the email has bounced because it's not a recognised address .. does anyone have a contactable email address ?
The earth clamp & cable is seriously weed compared to a good one, no idea if that is important for a plasma but will be using my decent mig one.
I noticed there are different ones on ebay for the torch. I think I read on one of the threads that the consumables are avalable in different lengths (I think the ones for this torch are the longer ones but will need to check), so anyone looking to get some on order, just check your ordering the correct ones!Standard pt31 torch it seems so ebay is your friend
customer.services@lidl.co.ukI've tried several email addresses and the email has bounced because it's not a recognised address .. does anyone have a contactable email address ?
Think I'd carefully solder the cable ends so there is no wicking of solder up under the insulation or better still slip them into the right sized crushable sleeve then put them in the plug & tighten the holding screws .Not cut anything yet, but will be soon 8 & 10mm
The commando plug was wired by someone in a rush to the bierkeller, the cable restraining gland was doing nothing as well...Reterminated and but a cable tie behind the gland to keep tight.
The internal compressor on start sounds suspiciously like parksides battery powered pump - which work ok.
Check the cables guys..
A full bladder as well ?S'funny...I went into Lidl a day late today and was almost glad they had none left.
Yet I've just been up the pub and done over £20. What have I to show for it but a warm happy feeling?
In the grand scope of things.....£149???
Thank you email now sentcustomer.services@lidl.co.uk
I emailed them a fortnight ago to ask when they would be in the U.K.- it obviously worked because two weeks later here we are!
They will reply - I mentioned they were getting talked about on here, and the reply I got said they would pass that info on to the buyers.
That's always better ,I'd go with crushable sleeves , but I have to admit that I do solder , because lacking of tools and materials.Think I'd carefully solder the cable ends so there is no wicking of solder up under the insulation or better still slip them into the right sized crushable sleeve then put them in the plug & tighten the holding screws .
One thing I've found over the years is it's not uncommon for bare wire terminations to loosen & come out as the cable is moved about &the layering of the copper settles a bit more . Those copper whiskers on the blue wire are disgusting
I wonder if you could use one of these set to say 5a to trigger a relay which breaks the nozzle ground once it detects 5a on the work ground.It should have a power resistor connected in series to the ground to limit the current going to the nozzle preventing to destroy consumables and limiting the cutting capabilities
It should work but you need to limit to 5A or better 10A the current going to the nozzle.I wonder if you could use one of these set to say 5a to trigger a relay which breaks the nozzle ground once it detects 5a on the work ground.
WCS1700 Hall Current Detection Sensor Module with Overcurrent Signal Lamp DC 5V | eBay
Find many great new & used options and get the best deals for WCS1700 Hall Current Detection Sensor Module with Overcurrent Signal Lamp DC 5V at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
So relay would be normally closed, when there is no connection between the nozzle and workpiece the current flows between the nozzle and ground. As soon as you start to cut the workpiece and get a connection which reaches 5a the sensor triggers the relay to open which breaks the nozzle to ground and instead forces it to go nozzle to workpiece.
Opened mine up to check everything, nothing major that could be an issue
