Hood
- Carnoustie, Scotland
If anyone understands my pain it should be you!
That must have given goosebumbs and a bitter taste![]()
I prefer spiral point but I couldn’t find any for good value....I hardly ever buy spiral flute, then again nearly all the stuff I tap is through hole. I have found spiral points just breeze through stuff compared to spiral flute and they centre a lot better if tapping with a cordless drill.
The taps are JIS shank which they failed to mention![]()
There’s the most common which is iso then there’s DINAre those different diameters to ours?
Have you got a link to the tapping arm or has that sold out now?![]()
Just go on vevorHave you got a link to the tapping arm or has that sold out now?![]()
I know somebody who'll check prices up until the free return period has ended, and if the price drops enough make it worthwhile, will contact the seller for a partial refund, and if they refuse, they'll send the item back, then reorder it.I learned a long time ago never to look back at the place I bought an item from![]()
What size tap was that??In 25 mm mild steel with a used spiral tap it’s on its limit so no fancy metal though a new tap might help
Biggest thing is air oiler is total junk!
300 plus 99 pence delivered now.![]()
VEVOR VEVOR Universal Vertical Type Pneumatic Tapping Machine Flexible Arm High Strength Machine Arm 1000MM Air Tapping Arm Collet M3-M12 | VEVOR UK
Discover VEVOR Universal Vertical Type Pneumatic Tapping Machine Flexible Arm High Strength Machine Arm 1000MM Air Tapping Arm Collet M3-M12, High-strength Material and Simplified Operation at lowest price, 2days delivery, 30days returns.www.vevor.co.uk
Danyang Taipusi, I think, I have a few.Bought some chinesium spiral taps off eBay to try
The price seems to good to be true and I would risk on anything fancy but for dirt work like laser cut stuff I’ll try
this is my collection
