I have a diesel compression tester kit that you can borrow if needed.It bled out really easily, I took a video of the spray pattern, but cannot work out how to get it out of my phone, looked ok BUT no smoke from exhaust, plus oil looks to be full of diesel, I suspect it is not atomising the fuel under pressure and is just flooding the piston, OR the rings are knackered, it has compression but I cannot check how much, engine kicks on the rubber mounts as it cranks over,
New nozzles in the injectors would probably help but test the spray pattern first, as above.
