pressbrake1
- Essex
That will drill the hole with a drill you don’t need a crane to install, far more accuratelywhat do they use now..?....a £100,000pound CNC I guess.....now thats progress.....!!!!!!!!!
Yes you could probably use a lesser machine for our needs... but why would you want to?Actually it’s handy to have a ra drill to drill and tap billets for lifting eyes to then be able to load said cncThat will drill the hole with a drill you don’t need a crane to install, far more accurately
Urban mythDo you ever wonder if there's such thing as too big?![]()
Your not limited to size with the drill either as workpiece is still and can be hung from a crane etc
I once drilled out broken bolts in s truck engine by tilting the cab then swinging the drill arm over the job
Handy things if you have space and proper fitting skills
Did you have help?Actually it’s handy to have a ra drill to drill and tap billets for lifting eyes to then be able to load said cnc
You need some..Did you have help?
