What is the point? I had to remove an injector pump today from a JCB loadall with JCB's own dieselmax engine and because the timing gears are at the rear I had to remove the entire engine. And you need a special tool to remove the cover from gear. Another special tool to press the pump shaft from the gear. And it's a plain taper fit with no key or spline. I hate modern kit.
