Johnnybravo
- Northiam
No issues with regrinding jaws as long as it’s done properly, which most people don’t
And even when they do they're left radiused, not flat as originally.No issues with regrinding jaws as long as it’s done properly, which most people don’t
Have a good look at a set of jaws. They are radiused from new. Well , the jaws on the Colchester Mastiff are, the jaws for my Bison are, the SWM auto blok ones are, as are the ones from my Hitachi SeikiAnd even when they do they're left radiused, not flat as originally.
I'll have a look, they didn't seem radiused to me. Or do mean you convex, which would be fine. Concave isn't what I would want, except on soft jaws.Have a good look at a set of jaws. They are radiused from new. Well , the jaws on the Colchester Mastiff are, the jaws for my Bison are, the SWM auto blok ones are, as are the ones from my Hitachi Seiki
Most chuck jaws are ground concaveI'll have a look, they didn't seem radiused to me. Or do mean you convex, which would be fine. Concave isn't what I would want, except on soft jaws.
You are absolutely correct.I reground a set of jaws for the Mastiff using the jig I made in the photo. Totally transformed that chuck.
Yup. Anyone who thinks Colchester/Harrison had great build quality is sadly mistaken. The castings and design- well enough... the assembly... barely better than chinese stuff today. Some really good machines out there... and some real friday/Monday machinesNow for something completely different......
When I checked the Student lathe to find out why the oil point on the leadscrew end bush was blocked. It turned out that the casting core had never been cleaned out. So for 60yrs it wasn't used. Must have been oiled from the ends.
On my Senior Major mill the suds pump belt wouldn't last. Turned out that the pump had never been completed. The relief valve for the positive displacement vane pump had not had all the drillings done and was overpressurising.
So much for 60's QC?
Chinese quality has improved a lot. Made in Japan was the pits in the 60's...and now?Yup. Anyone who thinks Colchester/Harrison had great build quality is sadly mistaken. The castings and design- well enough... the assembly... barely better than chinese stuff today. Some really good machines out there... and some real friday/Monday machines
Absolutely, thats what i mean. Current chinese assembly quality varies a lot but on average probably about the same today as Colchesters assembly back then...Chinese quality has improved a lot. Made in Japan was the pits in the 60's...and now?
As Sean Lock said " I'm practically Chinese" But didn't we used to be an engineering nation?Absolutely, thats what i mean. Current chinese assembly quality varies a lot but on average probably about the same today as Colchesters assembly back then...
We still are, if you look around. Just not a manufacturing nation.As Sean Lock said " I'm practically Chinese" But didn't we used to be an engineering nation?
'A nation of shopkeepers'We still are, if you look around. Just not a manufacturing nation.
