daedalusminos
- Norwich
That's such a good finish the camera was unable to focusNext up is a piece of F51
Here is an example of what I am saying.
Both were same insert, same spindle speed, same depth of cut, same feedrate.
First is some kind of mild steel, no idea exactly what.
Thanks was not sure on the correct procedureWhen you're checking for loose bearings do it by lifting up on the chuck not barring it front to back. You'll be lifting against the weight then and any looseness will cause a jump in the needle.
Ok a drawing in fusion.
Tool rad 0.8mm
First part is 0.3mm/rev, second is 0.15mm/rev.
As can be seen grooves there but much less pronounced at the lower feedrate.
Just make sure once you've ground to the desired profile you spend time honing the cutting edges ,I use a diamond hone .Wow thanks for all the help on this folks
Pretty sure the belts are not the issue as same problems with running 1 belt as with running 3 and they are matched so no issues there.
@Munkul I know what you mean with the insert that was a photo from before I knew better just to show the finish , I was trying some of those ultra sharp alloy inserts and it still gave a line finish on lowest feed rate but it did feel smooth to touch just not a ground type finish others experience with them.
This is the alloy VCMT finishing insert result, Some of the Kennametal 0.4 radius inserts gave a nice finish but still lines unfortunately.
@prepman yes I am less inclined to fiddle with bearings when messing them up would pretty much scrap the lathe lol. Will have to try the play test once the lathe is warmed up aswell see if that changes the amount of play.
@Fortis maybe should have a go at the black art HSS sharpening
Intresting idea , The vibration is worst when the frequency was about 40hz which equated to near 1000RPM. When above and below the vibration is a lot less so this is certainly worth considering.
Intresting to have it rub slightly rather than cut , Would you have any photos of the grind on the tool as I say I have only ever used carbide. My motor is mounted in the lathe cabinet.
Coolant pump is nearly set up but will have a go without it and post some pics.
@Johnnybravo Good call on the levelling , I had a loose foot which made vibrations even worse that is snugged up now and I am hopeful that the vibrations are not caused by a bent spindle as they are worse at 1000RPM at full speed 1200RPM they still vibration but less so where as I imagine a with a bent spindle the faster it is the worse it is.
@Lewis_RX8 do you know anyone that could lend you some 'chassis ears' basically they're an electronic stethoscope that can display the vibration frequency, amplitude and in some cases, direction to source. It may also be worth looking at the motor mounting and putting a DTI on the motor casing to see if there is any deflection worth worrying about.
If it's rebadged 'Steelman' kit, it's shi'te, otherwise if you can get hold of a loan or demo kit, it should help.Hmm I could do a screwdriver to the ear that my fancy stethoscope lol, Seen some SKF condition monitoring stuff that is like that really nice bits of kit now over Bluetooth and can look at logs of vibrations and frequencys quite fancy.
You won't get a true run-out measurement like that, the DTI should be at 90deg. to where you want to measure the run-out, that looks to be roughly 45deg, which will give you an indication, but not a true measurement.Like this ?
Should I just spin it and measure runout or try and flex it in some way?
Thanks
I find if i am turning a bar of "draggy" steel that's giving feed lines i just max the chuck speed out and go really fine on the cut with sharp HSS...really helps things out.
In softer steels, suitably ground/sharpened HSS does typically give a better finish, especially with small cuts.I was getting lines like that on my much weedier lathe. Tried HSS with a fat radius and managed better. Stay away from pointy carbide.
12mm diameter.
Just to clarify, my pictures were of a roughing feedrate of 0.3mm/rev. It was done specifically to show the difference in appearance between different materials.I was getting lines like that on my much weedier lathe. Tried HSS with a fat radius and managed better. Stay away from pointy carbide.
12mm diameter.
Also big difference between hot and cold rolled.Mild steel will mar and rip as it cuts, higher alloy steels will cut better with less ripping. Aluminium and stainless are more ductile so tend to leave a really nice finish as they sort of smear.
The problem with going too low on the feedrate is you will get long stringy swarf which will mar the surface of the material you have just cut.
I ripped out the old switchgear out and put the VFD in there. The motor had been repaired, the ends of the windings had been jointed internally, making it permanent star, which was no good for 240. So I had to separate and extend to a new terminal block to make it delta. I am certain that the vfd should never be disconnected from the motor, but switched on the supply side. For belt & braces isolation I unplug it (13A).That's the plan at the moment seems cheapest and easiest way to get it sorted so should be fine
Interesting, just for mild or all steels? Im aware that cold will move as the stresses change but no idea if it cuts better or worse.Also big difference between hot and cold rolled.
