Did you sleep at all last night?
Well done for finding a manual.
That's quite similar I desigN of the deckel / Alexander college but obviously a lot larger if they go to 20mmThese are the collets I'm fairly sure. They come in at least 2 different lengths as I've also found them quoted a bit longr but either length would do.
@Pete. Did you get no joy from the previous owners then ? as it just sat there unused because they had no tooling ?
That's probably the same type as the older S0 grinders used, I've got a set I can measure if you need the dimensions. Good luck finding them, I've never seen another.The high speed head uses a similar style collet with about a 16mm shank. Need some of those too![]()
S0 collets far too small. They couldn't take a milling loadThat's probably the same type as the older S0 grinders used, I've got a set I can measure if you need the dimensions. Good luck finding them, I've never seen
Few £ of gear cutters!
I`ve sold it
Bob
