But you still have to ramp up enough energy to start the machine moving - which is the same amount regardless or rate of application of energy. For example, I have a spring gauge for measuring the breakaway force required to turn a wheel hub, the force is the same whether I pull on the gauge slowly or quickly. I appreciate the way a VFD applied 'energy' is different than plain old fixed voltage & frequency mains, but the energy required must be the same, just over a different timespan.My guess is it’s because m_c uses his vfd as a static converter rather than using it as a vfd, if you do it this way and utilise the existing switchgear you need a significant margin to allow for start up currents, which can be many times the running current.
If you use a vfd as a vfd (if you see what I mean) this problem doesn’t really exist as it’s able to ramp up smoothly (and monitor and limit its own current if required) and you don’t need the overhead if using DOL or star/delta starting.
Yes, but you don’t need to build in an “allowance” to give you a safety margin which you would need to do with a dol starter, or to a lesser extent a star delta starter on a larger motor.But you still have to ramp up enough energy to start the machine moving - which is the same amount regardless or rate of application of energy. For example, I have a spring gauge for measuring the breakaway force required to turn a wheel hub, the force is the same whether I pull on the gauge slowly or quickly. I appreciate the way a VFD applied 'energy' is different than plain old fixed voltage & frequency mains, but the energy required must be the same, just over a different timespan.
motor definitely has two speeds, but doesn't necessarily mean you have to use both. It might be possible to rewire only for the higher speed and control to suit via vfd frequency?
don't know, just thinking out loud.
My thinking was that you would get a bigger choice of cheaper vfd to run a dual voltage motor rather than having to use a step up vfd to get 400v out. Probably go some way to offsetting the cost of a motor, plus you’d get a new inverter rated motor as well.Replacing the motor with a 230v one wouldn't really be of much benefit as you would still just have a single speed motor, exactly the same as you would if you chose one of the speeds from the current motor.
Rotary (or static with motor to make rotary) would be the best solution especially if wishing to run multiple machines. I had one years ago, just a static one but fitted an idler motor and it worked great for my Student lathe with the 2 speed motor and third shaft control (no clutch, motor stopped/started/reversed with the spindle)
That being said a Static and motor or a rotary will set you back a lot more than a VFD, that is why I am curious how @m_c uses his VFD in place of a rotary as that could be your best option.
The lower speed on your motor is half the power and half the speed. You will loose nothing by connecting it up for the higher speed and using the vfd to adjust speeds.
Often the lower speed is done to get a higher torque and similar overall power, but not the case with yours.
A new 230v capable 3ph motor is not going to be cheap even if the vfd was cheaper. You may find something used on ebay tho... Lots of motors that are too big for home use.
Yes, it was the bottom of my list of options but an option none the less. Not forgetting you could almost certainly recoup some cost of a new motor by selling the old one.Aye but 230v VFD and new 230v motor would likely cost way more than a 415v VFD. Probably getting into rotary phase converter territory and if so I would prefer that way personally.
True...Not forgetting you could almost certainly recoup some cost of a new motor by selling the old one.
Just set it to ramp up to 50Hz. The issue is finding one that can handle having nothing attached to it (I still have the idler motor from my rotary attached for this reason), and isn't overly sensitive to shock loads.How do you set up a VFD to act as a 3 phase supply for multiple machines?
Do you really need the low speed?That's what I was hoping use the VFD function for dual speeds
Think it depends on the windings so will open the box and have a look when I'm home
Typical electric motors theoretically are constant torque, so you don't lose torque as speed drops, you lose power as the motor isn't spinning as fast (power = torque * speed).that was what I was thinking, ok you'll lose torque as the frequency / speed drops, but seeing as you only need half the the power/speed anyway, it would probably still be sufficient. Worth a try anyway.
It’s as much to do with the type of load rather than the drive, most of my work has been with fans and pumps rather than machine tools so have been the variable torque loads. There’s usually a setting in the drive so you can optimise it for which type of load it will be connected to.not sure about constant torque throughoout the lower frequencies. Pretty sure it drops off, or is it the other way round? if I remember rightly there's a ratio between the frequency and the motor output torque, and you can calculate that loss fairly accurately. When I get an hour or two, will have to refresh my memory as it's a while since I've commissioned any. Did plenty of them on the last HVAC job, big AHU's and fan sets, those were all danfoss drives, but the theory was the same..
