Ubique
- East Midlands
Here's the problem:
There's a HV cable assembly that needs changing on a lot of MB Hybrid vehicles, the cable runs from a socket on top of the gearbox, on the bell housing, across the top of the gearbox, onto the body and then to the NSR of the vehicle. Even with the rear of the gearbox dropped as far as possible, there is no room to get 'hands on' with the plug, it's just possible to remove it's protective shroud, removing the plug is easy once the E10 bolt is released.
I've done about six so far with another ten or so booked in for the next couple of weeks, I've been 'steering' the plug with a combination of twisting the cables and pushing with a couple of long extensions on the E10 bolt. A better method was needed.
A lot of practice required, especially fillet and dissimilar thickness materials. Overall I'm happy with the design, well until it's first test on Monday, I probably need to make more of them to practice the welds. Only one touch-down though.
Also, it's not fully deburred in the photos above, I did a lot more cleaning up around the business end to ensure no potential for damaging cable insulation.
It's a bit of a niche item admittedly and it's a practice piece that has some use, not just covering plate up with filler.
