Dr.Al
- Gloucestershire, UK
Balls!
Today (and yesterday) I made almost all of these:
The one in the top-left is an off-the-shelf R8 arbor for a boring head. I had the devil's own job getting the arbor off, so I milled a couple of flats (with a carbide end mill as it was tough stuff) on it to make it easier next time. The rest (apart from the screws & dowel pins) were home-made. Made out of 50 mm square EN1A, 50 mm round EN1A, 16 mm square EN1A, 10 mm round EN1A, 32 mm round brass and 50.8 mm round stainless of some sort.
Joined together, they look like this:
The boring bar's adjuster screw has a hole of sorts on each end, so, having put the new tool in a tool holder, I used that with a couple of centres to get it at the right height:
Then it was a case of giving it a go:
It's not perfect but not bad for a first go.
This has been on my project list for about 10 years. About 5 years ago I decided to just buy one and I bought one that was designed for Myfords. It didn't work very well with small diameters as you had to have a big stick-out from the chuck or the chuck would hit the body, so I filed it away with the idea that I'd think about it some other time. Yesterday I needed a ball for a repair job and decided to just get on with it and make the tool. The design was very much a case of "make it up as you go out of whatever you've got", so I'm sure there are imperfections in the design, but it seems to work and that's good enough for me.
