If it’s the sort of stringing that Parm shows in his post at the top of p23, it’s usually because the print hasn’t stuck to the bed,,which it turn may be because of a dirty bed surface, or the nozzle height not adjusted correctly. You can also get very fine stringing, eh across holes or between different components if more than one is being printed at a time. I’ve never bothered worrying about this as it’s easy to clean it up when the print has finished. I think that playing with the settings may help as I remember watching a YouTube video on how to improve quality.Another question.What's the primary cause of stringing?
The 32 bit upgraded version. £280 on Amazon but I paid £170 delivered from the manufacturer's website. I got a Kilo of black PLA and a kilo of blue PETG to make the brake flush funnels which I need urgently.Which printer you gone for?
I offer a quote from the Prusa website. "If you don’t feel like tweaking any of the settings, well, then there is an alternative. You can get rid of the strings with a heat gun (or often with a lighter – but be very careful). Set your heat-gun to around 200°C and aim at the strings for one or two seconds. This will melt the strings, and the printed object should remain undamaged."What methods do you use for cleaning it up, when it happens? I've just snipped it off, then scraped the surface with a blade. Are there better methods?
But read the fan specs first. In some cases Noctua fans do not provide the same throughput as other makes. If your application can live with this then fine.yes, search for Noctua
Pretty much exclusively!I take it "f'ed if I know" is going to be a common answer you give yourself then?![]()
Does anyone else have a resin printer rather than a filament (FDM) one?
Just beginning to think I'll be asking myself for advice as it doesn't seem like anyone else has one...![]()
