I am fascinated by this - what did the "pin" in the valve cover actually do?The pin in my hand had snapped off in the valve cover of this engine, instead of trying to shape the aluminium weld back into a pin, I built it up with weld, then drilled and reamed using a guide block I made, then press fitted a 4mm dowel pin with bondloc 620 for good measure
I've also swapped the oilers for ball type as I can just pump oil in ( made an right angle one for the one above the knee gearbox as it is hard to get to with the belt on.
