Brazil has E100!
Some people recommend adding water to the fuel and draining the resultant water alcohol mixture off of the bottom.
I work on small engines, I never used to have to replace carburetors.
The E15 makes the aluminum get white and dusty with pockmark holes, and the brass parts turn green.
The majority that get replaced are the ones on tillers.I would not use E15 in a small engine unless I was certain that the manufacturer had upgraded the fuel system components to be compatible with higher ethanol levels...and that it wouldn't void the warranty.
Even though E10 is now approved by many small-engine manufacturers, I would still prefer not to use E10, but depending on where one lives, it can sometimes require a fair drive to one of the subset of stations that still carry non-ethanol fuel.
twice
That said, I've been using E10 in my small-engine equipment for quite a number of years now, and after what I might call a "transition" period some years ago, when I had to overhaul several carbs, etc., I really haven't had much of an issue with it for some time now. I think most of the newer machines and newer replacement parts use materials that are more ethanol resistant than the older ones. I currently have something like 17 different small petrol-powered equipment items, and the remaining fuel only gets drained once a year, after about a 6-month usage season.
I don't know what the E10 compatibility situation would be in the UK.
I should mention that we do have E85 fuel here at a 'relatively' small number of stations in most states, as well as quite a number of Flex-Fuel vehicles, although E85 has not gained a huge amount of popularity.
https://en.wikipedia.org/wiki/Flexible-fuel_vehicle
Marvel Mystery Oil "
Just make sure you get injection hose if you need it.I suppose its better to get with the program rather than side step the issue and rehose fuel lines to cope, Gates are already on it https://www.moss-europe.co.uk/ethanol-proof-fuel-hose-by-gates.html
Bob
Exactly my findings with small race engines and lawnmowers. It's worse now with lawnmower engines where the jets are ECO-fixed at the factory and you can't get them out to clean the thing properly. I've seen jets so blocked solid that I actually thought they didn't have a hole in them. I have to make up micro drills from throttle cable to start breaking through.I work on small engines, I never used to have to replace carburetors.
Why? Is ethanol cheaper?Fuel that has 10 percent ethanol added.
What is the reason to create it?They started with E10 over here and then went to E15, each step is multiples worse than the one before.
Higher cost and less fuel economy.
I'm finding it's causing havoc with two stroke engines.. The brassware quickly becomes dull and covered with a green tinged deposit that accumulates when left for a very short period. The ethanol seems to react with the oil mix and becomes a solid. The picture is from a 125cc catburetor that had a mix of e5 and She'll M. This was the state of the filter after less than an hour of running. E10 or 15 will render these high revving engines useless. I'm thinking of making a rig up to separate it out and sell it.
I came across a plastic pick up pipe the other day in a tank that wasn't drawing fuel up. The pipe had swelled to four times its original size and just crumbled when I tried to take it out. Took bloody ages to fish the bits out. The thing was, once it was out of the fuel mix, within a day it returned to the right size.Just make sure you get injection hose if you need it.
Its been quite difficult to get genuine Gates hose that resistant enough to our current blend when its installed inside a tank - my Lancia failed to procede a few years ago due to the hose I fitted inside the tank not being the spec it claimed to be - absorbed the fuel, swelled up, rotted and failed . . .
Some carb manufacturers have had nightmares with the diaphragms swelling. They have had to research into using thin metal and plastic units to overcome the problem.strange that I'm finding it less problem on two strokes though, mostly chainsaws etc,. Typically the ones I see are worked pretty hard around here (fire wood) so maybe it's because of that, but will keep an eye them to see, but it's definitely an issue of 4 strokes
