James1979
- Orkney
Reasonable. I need to refine it a bit. Still making a profit but I had expected to use the first batch as a learning spike so happy with that!Looks nice and quick. I like it. Hope you're making a good hourly rate.
CheersGreat solution.
aye, I've done a few jobs that to be honest weren't worth the bother, and just taking a hit on the time with the expectation it's going to lead to more (better paying) work later. To date, it's mostly paid off, sometimes you need to invest / be optimistic, at least I'll continue to look at it that way.If it was a smaller run I wouldn’t bother. I am making a reasonable wage out of it and it’s led to more work.
fettling the tooling takes the time. Which is why if it was a small run it’s not worth it for me.
I’m lucky I can plasma the blanks. That reduces a lot of time taken. Even if I need to babysit it, it’s a relatively quick operation
I've recently 3D designed & printed a trigger in ABS - T for my litter picker / extended picking device .Not made, but fixed. Next door neighbours go Litter picking. The grabbers break. I fix them, The one today was a pin lost from the trigger. It took me longer to print my 'FIXED BY DAVE' sticker than it did to put a bolt in it. I don't charge them. I make noise, they don't complain.
Ardy ,Few more things that has had me entertained.
Couple of Hammers, both heads were loose on the shafts.
Both had nails forced in against the soft metal wedges to try and keep them tight.
So both had the nails removed, shafts cleaned up. Heads were cleaned with a bench grinder wire wheel.
The hole in the head was cleaned up, then 80grit paper was used to give a rough surface.
New Hardwood wedges made, then the heads refitted.
This 1/2" hand masonry drill has had a good deal of use.
Blunt, head mushroomed and a damaged flute.
I had time so why not.
I even redressed the tip. The information was in a Home improvement book, from the 1950's.
This square was one of those small jobs that was done to fill in time between the others.
The is the best side. The other was covered in white paint. That was easily removed with modern paint stripper. But the blue paint was some sort of Hammer finish, added in it's life.
Hot caustic dip had that off, then a clean up of the blade with a brass wire brush. The square faces had the rust removed with 800 grit wet and dry on a glas sheet.
All done. Just a few more coats of hard wax needed.
Fill the container with water so the depth of the water is half as much of the height of the item to strip.Ardy ,
I have a 5 kg tub of caustic pearls . what is the ratio of boiling water to your caustic that you use ? Do I take it that you drop the caustic into cold water then it heats up due to thermo reaction and then you bring it to a boil .....is that correct? .
Circa 1955... At the local blacksmiths the smith used 5/16 ( 8mm ? ) foot ( 300 mm ) long split pins that he reheated to make a big eyed split pin then put a Whitworth thread on the now reclosed split pin leg ends s . The ring would go over the snaith and some thread would poke out the drilled & counter sunk handle then pop the nut on and wind it down into the the counter sunk handle . Often the guys with the scythes had two side handle on the scythe some 30 degrees off set from each other especially if they were cutting hay by-hand or scything out the ditches to get lesser quality hay stack covering materials.Made a scythe for mowing the ditches and other areas around the yard, dislike firing up the weed whacker and much prefer this.
Norweigan carbon steel blade, homemade snath in eastern european fashion with a single handle and wedge style attachement. I need to work on the handle ring yet, didn't get it the proper size for the snath (which is hand carved so not perfectly round or straight all the way). Had to resort to some shims to make it fit for now. I have made it so you turn the handle to tighten the ring around the snath. The idea is you will be able to easily move the single handle to where you want it without tools. I might make it into a two handle setup yet though.
Had to reinforce the snath, it broke more than once. Fir isn't the ideal material... But cheap and light. I should probably weld up the whole side, would look better.
couldn't find anything suitable at the scrappers
If you're not in a hurry, you don't need anything like a saturated solution, and it doesn't need to be heated. Of course it's so cheap you don't really save a lot by being stingey mixing up the solution but I had good results with probably about 200g in 20 litres, no heat just stood in the garden overnight. Rinse in clean water (Pressure wash if you're lazy) and then another night in citric acid does a fantastic job of stripping both paint and corrosion.Fill the container with water so the depth of the water is half as much of the height of the item to strip.
So a 100mm high item with need a depth of 150mm.
Add the caustic until it starts to stopped being absorbed, in tepid water. Add tepid water until the caustic t is dissolved.
Add the item and warm.
Test the paint removal by rubbing a blunt plastic tool.
Then wash in warm water.
Simplz.
