Yes, I’ve run a big motor (2.2 kw) off smaller drive (0.5 kw) - with no load it should run fineI have a VFD I could potentially use to test the motor. However, my VFD is only rated at 1.5kw and the kotor is 2.2kw.
Could my VFD be used to test the motor without a load?
I have a VFD I could potentially use to test the motor. However, my VFD is only rated at 1.5kw and the motor is 2.2kw.
Great. Thanks for the info.The 2.2kW is for pushing a wet, green, 4" thick oak plank through a blunt blade. A bare motor, maybe without even a pulley connected will desire way less than this.
For good, brand name VFDs, the rating is its 100% duty cycle (unlike most welders). They will stand 150% or 200% of their rating for a short time.
To really be conservative, set the VFD for a long ramp-up (greater than 5s) time. The VFD is smart enough to protect itself in case of an overload.
thats an old motor you have the modern ones dont have as many windingsGreat. Thanks for the info.
I have got only branded VFDs. One Bosch Rexroth and two ABB VFDs. All three is 1.5kw.
The motor settings is going to be troublesome. I have NOTHING to go off by.
I might need to google the specs on a similar sized motor and try those settings.
job doneYou are right. BUT it will never be as cool as this old motor. It is so heavy and solidly built. I can't bear seeing it go to the scrap heap.just get a second hand single phase motor and bang it onjob done
could you realy be botheredIt will definitely not just be scrapped! Too much copper in it, so it will def be recycled.
i save copper  but only what i have taken out of  jobs and have a  machine i made for stripping  cable real fastcould you realy be botheredi save copper but only what i have taken out of jobs and have a machine i made for stripping cable real fast
I did not take a photo and was typing a lengthy reply of how I am SURE I connected it up correctly explaining what I have done.Could you show us a picture of the way you have connected it for running in delta. There might be something subtle that you have missed.
.The block is wired correctly now (second photo) and the motor runs in DELTA.The block is wired correctly. Strapping across each pair should have worked.
Is the labelling taken from the wires or from the block? Or, are you assuming that the wiring plate information is as they are presented?
