First things i look at are washing machines kettles and immersion heaters, basically anything with an element.A clamp meter to hopefully help find why the bloody RCD at home keeps tripping!
I fault find earth leakage faults all day at work but can I find this one!![]()
Another vote for appliances, fridge/freezers, electric showers, just because you cant see appliances leaking water doesnt mean it isntFirst things i look at are washing machines kettles and immersion heaters, basically anything with an element.
VGC SKF Puller
I had to modify a cheap chrome plated Chinese one the other day to fit in a gap so I thought I better replace it with a proper puller that will take some abuse if needed.
Very hard to find skf stuff used but it’s so well made.
£85 off eBay, very lightly used.I had to do the same and lucky it worked before it failed, had the ground down claws failed I wouldn't have cared too much and gone for another.
What did that tasty SKF set you back?
You really need double pole isolation on everything so you can isolate them one at a time, Id be amazed if you can find the fault with a clamp meter though
I friggin love the SKF stuff, especially the mechanical pullers! Good price for a good size!VGC SKF Puller
Yep it’s lovely stuff. I would like to get a few more sizes or some of the handsfree ones.I friggin love the SKF stuff, especially the mechanical pullers! Good price for a good size!
Can they be used to drive an auger for digging holes? (I'm guessing not, since there's no clutch?)
Course they can. Just make sure you have someone videoing it when you try.![]()
