hotponyshoes
- Somerset. Uk
I managed to get one and learn how to print stuff and I can't even watch porn without making a mess so it can't be that hard!
Remember to order some filiment and also some acetone/ipa or what ever is recommended for your printer (if it needs it)
When drawing stuff I found it helps to make plenty of saves as you go along,
Draw the outline plan, save as v1, then as you add to the model save as v1.1, v1.2 etc.
If you make any big changes than save as v2.1 etc.
After you have spent a while drawing stuff up you often find you need something similar but not quite the same and a part drawn previous model might be perfect for that and quicker than editing a completed one.
On the same note, if you need something like a part with recessed for M6 nuts, rather than draw the recess directly into the model, draw it separately and save it in a folder where it's easy to find ie c:3d components/nut recesses/m6 nyloc.etc
I reckon I am modeling things that are twice as complex but in half the time compared to when I first started.
It is nice to be able to quickly find something on thingiverse and just print it out overnight but it's also a lot more useful for the custom stuff like jigs and brackets that you want custom made but don't want to spend hours manually cutting from bits of metal or wood!
