Progress is progress, it's good that it's moving forward, how's the loom coming along?
Wow, those crimpers are a bit spendy, especially the TE ones but not surprised as most TE stuff isn't cheap
I've used cheaper ones for crimping Econoseal terminals and they seem to do the job OK
I always struggled to make wiring looms look good after modifications, more practice needed I guess and Project Binky has given me some inspiration
Do share your learnings in regards to painting I've to go down that route and any anything I can learn from others would be great. For 1mm and below sheet B&Q has actually been pretty useful for me if you're looking for materialWill also be using some of the larger panels to practice painting. Or at least so that my first time using a spray gun isn't on my car![]()
This is the crimpers
And these are the connectors and terminals
Thank you. I think these ones are similar to the cheaper crimp set I posted above. My set offers more dies for a wider range I think too. May I ask how much yours was?
I don't think it will cover the Deutsch connectors. I think they are very much proprietary.
Pics of acquisitions, please...
...Oh and this compressor. It's 50 ltr. I made a mistake. It's already up for sale and i'm going to get a 200 ltr. Better just bite the bullet now I guess. I didn't realise the tools I would be using are some of the most demanding (die grinder, sander).
I'll take a hit of a few quid, but will put it down as a lesson to do more thorough research in future. (I was too caught up with CFM figures).
very nice
i have a french hatch I'll be doing similar work to so I'll follow this closely for advice/inspiration
where did you get the spit from? I've thought about getting one as being on my back welding the underside does not appeal to me lol
Blimey those crimpers you’re looking at are expensive. Also look a bit awkward being two handed to operate. I have a mote basic set to the ones @indy4x showed. They do those terminal crimps nicely. I’d imagine his are a bit less fiddly than mine to, I’ll take a pic shortly if you want.
A nice haul!
I'd move that old Migmate well out of the welding area ... superstition.
Exactly. Along with my crashed car door I now have some steel box and offcuts to practice welding. I can practice mig and stick now.Nice!!!! Let the learning begin
Do you want to adopt an old Englishman?![]()
Where are you based anyway?Been there but should have known better, had a Clarke 150l, 14cfm compressor but was pushed for space, sold it and bought what you have in the picture and regretted it.
Visit to the local scrap yard and spotted another Clarke lurking in a pallet and it ended up coming home with me. It needed a new switch and had been in a carpentry shop minus it's air filter. New switch, filter, strip and clean the pump, refreshed the wiring and it's good to go.
My Sealy has 2 wheels on the back and a small platform for the gas to sit on and then uses chain that wraps about 1/3 of the way up the bottle to keep it parallel to the welder and I have to say it works a tread even with the big bottle of gas.
I know you're looking at a different direction but by the time you lift up the table top to weld on above the bottle it's going to be pretty high. I kind of like to lean over and be able to maneuver whatever way I want around a part so reaching up onto the table would be off-putting. You could however put the bottle just on the inside edge of the cabinet you have there so the valve is accessible and then to help counterbalance come of the weight extend your welding table ledge to the opposite side.
