angellonewolf
- bristol england
after having problem with my roof for a few years since we moved in on the extension its a flat roof with a slope runs away fine with little puddles on the roof when raining but i keep having water marks on the inside near the house on the plasterboard near the joint between the house and the flat roof we thought we had fixed it when we had the windows replaced and put in more lead over where it was leaking now its found another way in so this is not throw as much as we can at it but i want a fix and done for the next 20 years plus so a proper job
pics of problems its easy to spot now the render has been taken off
first thing the lead is not even secured or mastic or cemented in plus there is no upstand with out going in to a big story the window you see in the pic was down to the roof so there was no room for an upstand an relyed on the lead to flow the water away from the wall as can be seen now the render is out the way the lead is carp
now the roof is fiberglass and im sure ive seen on the fourm this can be sanded and then added to then a top coat applyed again to make it as new ?
this will not be a quick job as im doing it between work so only a day here and there the main is to make water tight asap im assuming we should be ok for a few days so i need options and a shopping list for my ned day off
thanks for any help
thanks for any help
sorry treat me as stupid as a 90 degree wont move as much ?
