We'll see, I think I've found a good one this time.Give it a year or two, & you won't be writing posts like that.
Sorry, I've been good for too long. I have to do it occasionally.![]()
Treat her like a queen if you have.
Ooph, love those clamps.Bit of an odd day.
In a suit and tie in morning, few sherberts ina bar. With bar snacks.
Then back to potterin' the play pen. Had to work the beer through some how.
Some of the prep work was done when sleep was a distance memory.
Two Mitre clamps.
Both moved, but had damaged threads.
Google had found me a lot of information. Export models were painted, home markets ones were just waxed.
Yes I know the threads will strip the paint, but the description in the sales broacher made a point of all working parts painted with 5 coats of enamel.
Not silver leaf, but titanium. I couldn't buff it to get the colours to show.
Same time I got the 2 Hobbies clamp I got this geared Mitre clamp.
Both sets of clamps were left to soak in Citric acid.
Painted, waxed and waiting for use.
Burn baby burn, disco Inferno.I recently restored and converted a Storm lantern into a electric storm lantern.
Due to bad rust. But also the wick holed had failed.
I knew I had one, but couldn't find it.
I did today, when looking for my box of BA nuts and bolts.
Hmm, not pretty, also not moving. Plus no wick.
So, place in pan of hot water, caustic soda and pumice powder.
After 20 minutes, remove and carefully rub with wire wool, then let simmer in water for 20 mins.
So add a wick.
I haven't got a lot of spare acetal sheet, so I'd rather not remake unless I have to.
Made some gears:
Then had the fun of hand filing the keyway in one of the steel ones. The plastic ones were easier (although I overshot on one and hence it now has two keyways!). The steel one with the smaller hole (one is a spare) I haven't decided how it'll be held to the shaft, so that one will be dealt with later. A couple of the teeth on the acetal gears look a bit rubbish, but I think they'll be fine and I can easily make more if needed. I haven't got a lot of spare acetal sheet, so I'd rather not remake unless I have to.
for haylageWe've started making a big heap of grass.
yeh thats what i meant dohSilage
