I have an enclosure ..a very substantial one at that .
It's had a polycarbonate sliding front added
So far it has not gone above 22 oC .. have plans for cutting a round hole in the back printing flanges & housings and attaching a thermostatically controlled 2 " computer fan on the back ....ducting heat out of the house through an outside louvered flap via a pond water discharge pipe .
) dissolved in a few spoons of acetone based thinners in a metal topped glass jar ?no ideaABS slurry ..............scrap ABS ( now I've got some) dissolved in a few spoons of acetone based thinners in a metal topped glass jar ?
If you do that then wherever the intake air is coming from will cause a cold draught over your print and negate the point of the enclosure.So far it has not gone above 22 oC when printing .. I have plans for cutting a round hole in the back , printing flanges & housings and attaching a thermostatically controlled 2 " computer fan on the back ....ducting excess heat out of the house through an outside louvered flap via a pond water discharge pipe .
Yes. Pure white abs filament is best.no idea
I use ABS Pro.Watch the electronics getting too hot in an enclosure. That's why we haven't yet tried anymore ABS.
A lot build enclosures based on the IKEA LACK tables.
@ukracer is your man for ABS.
Found a formula .. How To Make ABS Juice, Glue, and Slurry | MatterHackers
I seems you can't use it on a plastic coated metal bed plate like mine .... I'll have to have a re read of my Prusa's operating manual
It will drag air in at the very top of the case front to an enclosed point 2/3 up the back wall , yes there will be some cooling effect but a simple slide across the hole baffle will allow me to regulate the air flow to a real baby breath pull to remove fumes . It will be a case of suck it and see , maybe even putting in a max & min temp range controller like I have made for my heated propagation UV light beds. I'll post more as things developIf you do that then wherever the intake air is coming from will cause a cold draught over your print and negate the point of the enclosure.
As I want to use the printed hinges outside , can anyone give me a clue as to how fast they will deteriorate if I use PTG or Pla outdoors ? Is it likely to be a few weeks , months , years or several years?
