dan.taylor.1
General Tinkererer
- Kendal, Cumbria
I can't remember how many times I've used the bandsaw vice as a 3rd hand or to hold some odd bit to weld it!Cut some aluminium tube up and put some of it into the mill and milled out the ends.
Then cut some plates on the plasma.
Welded them together using my adjustable welding bench
Then fitted it to the boat, MCA coming tomorrow for an inspection and gunwale has to be 1m high or rails to 1m.
The alert ones will see I have more pads (also more stanchions) than on the rail itself, that is because the skipper whatsapp'd me sized but turns out it wasn't needed so long![]()
7 out of 12 fit for the bin.... somehow they have deteriorated being stored in the box, out of sunlight and dry stored all cracked and split.. the bigger ones seemed to have faired better. inflated them and tested ok...fortunately the size I needed, one was ok...
Nice work, also!!
