If there's no fabrication drawings, I hope there's a lot of calculation drawings!Thats a lot of overhangWhats going underneath?
I did notice this also,Thats a lot of overhangWhats going underneath?
Designed and calculations,by an architect and structural engineer,probably fresh air underneathIf there's no fabrication drawings, I hope there's a lot of calculation drawings!
.I wonder if the overhang it is to do with the square footage it stands on & the ratable value > IE the smaller the footprint it falls into a lower council tax & ratable tax band.Designed and calculations,by an architect and structural engineer,probably fresh air underneath.
Like those medieval houses that got bigger as they went upI wonder if the overhang it is to do with the square footage it stands on & the ratable value > IE the smaller the footprint it falls into a lower council tax & ratable tax band.
I can't see any.All made from plans only,no fabrication drawings,that’s what I blame my 3 errors on.
I corrected them,the frame wouldn’t have gone together properly otherwise.I can't see any.
Mind you, I made a couple of glaring errors when building my workshop and managed to cover them quite successfully.
My axminster bandsaw has as much table either side of the band, probably as it swivels to 45° one way and 60° the other?A replacement material support block,for the outfeed side of the bandsaw.
Amazing how Axminster supply a good product (I assume they have some design input),yet leave off this vital part,without it your stock isn’t correctly supported.
Piece of 28mm square,and a 1/4” slot in the mill.
View attachment 289535View attachment 289536
This is also a swivel head,which caused the previous one to wear thru.My axminster bandsaw has as much table either side of the band, probably as it swivels to 45° one way and 60° the other?
I recently bend som aluminium tube, over an old powersteering pulley and these came out perfect, unlike the picture I took.View attachment 2892228mm copper lengths for compressed air cooler. Wanted a 180 degree bend in them. Have a cheap tube bender tool which works fine when Ive tried on brass tube. On copper it seems to twist/kink/flatten the tube instead
I hammered the bends back into a semi round shape. Might chop them off and buy some elbows.
the weather is an issue for start offIs that good going with a chest issue?
They are all full and he wants instant access. Drives sleep until needed to save power and prolong life.you might be better having a drive bay with removable drive slots
something like me i like save files alot so extra hard drive slots that can be unplugged and another drive inserted even better
