Good progress here!
Where are you with total costs - bearing in mind you know what your doing, an idiot like me might struggle with some of this..
A good question. Although equally one possibly best left alone (and I hope my wife isn't reading this).
I'll break it down because some would only be applicable to someone starting from scratch, some will pay less for their mill etc. I will exclude transport as well because that's massively variable. I'll also not bother with "material" costs as they're going to vary wildly depending on machine.
I will note that it's very easy for things to escalate and while a £300 milling machine may seem a bargain...it was £900 before I cut any metal with it.
This list is also missing a myriad of assorted bits and pieces, bolts, fittings, special grease (and second grease gun) etc etc. If I didn't already have an old lathe with imperial bolts I'd need spanners, allen keys etc etc.
Milling machine
Harrison Universal Milling machine - £300
Vertical Head - £375
VFD - £90.99
2x V belt - £7.92
24mm 1108 taperlock bush - £2.84
SPA75-2-1108 V Belt Pulley Wheel - £5.39
1.5Kw motor - £114
Replacement precision ball bearings (for ballscrew) - £7.42
SY Cable 4mm , 3-core - £11.96
Control
Lenovo Thinkcentre M58 USFF PC - £49.99
Mesa 5i25 & 7i76 - £287.78
Mesa 7i73 - £102.54
USB to RS485 - £2.51
SY Cable 0.75mm, 4-core - £14.89
3x MPG - £27.25
Conversion parts
Maedler 25mm clamp - £17.85
FK/FF20 End support - £55.30
FK/FF15 End support - £32.96
(Z) DFU2505-520mm (with end machining) - £60.46
(Y & X) SFU1605-375mm (machined ballscrew with end machining) & DFU2505-903mm - £131
4x 30-8M-20mm (TL) Timing Pulley - £45
2x 34-8M-20mm (TL) Timing Pulley - £25.38
3x 1108 14mm Taperlock Bush - £8.52
1x 1108 10mm Taperlock Bush - £2.84
KM3 M17X1MM LOCKNUT - £2.99
2x Angular Contact Bearing Open [7203 17mm x 40mm x 12mm] - £9.98
Motors (& drivers)
Z - Closed-loop stepper motor 86HB250-118B+HB860D 8.5N.m - £131.22
X - Closed-loop stepper motor 86HB step motor 12.5N.m - £133.80
Y - Closed-loop stepper motor 86HB250-118B+HB860H 8.5N.m - £124.24
