Jeez, that would do your head in.Here is a vid of the spindle noise. First I use with the headstock gears disengaged, I then engage them.
It most certainly did, as said the first week I got it I had to use it for 8hrs a day for a week, that spurred me on to fitting the servo in short timeJeez, that would do your head in.
The prices went sky high after that because other people started buying them, if only I could keep my bleeding mouth shut
Torque is is a bit low at slower speeds, fine for turning but for bigger drills it is lacking but it is a 4000rpm motor geared down 2:1 and I would have been better gearing 2.5:1 or even 3:1.Those Gamet bearings are quite happy at that speed. Might be tempted to do that to my old Triumph one day. What's torque like on those drives at low speed? Or is that why you part of at silly rpm![]()
How do the Scales work?
What a brilliant solution
Aye, seems to be and the ease of fitting is excellent. Shame the supplied parts for fitting are not the best. Fine for the Z axis but not the X and as it is supposedly a machine specific kit they really should be.What a brilliant solution
Aye, not so cheap nowadays, got some Samsung motors and drives from there but now they have doubled in price.I am a bit late to this but if anyone wants to see an alternative take on the servo spindle drive, this is worth reading:
Retrofit of 10EE Drive to AC Brushless Servo Motor
I mentioned in an earlier thread that I am converting my 10EEs drive from motor generator to AC Brushless Servo. Finally have gotten started on it. I now have all the parts for the motor. I am using a 2kw Mitsubishi Servo with a 3.5kw control. Got the control, encoder cable, and the motor off...www.practicalmachinist.com
A while ago, the best place for cheap servo motors and controllers was South Korea, via eBay.
