those patons have only literally just arrived in the uk market.. But honestly to me they look like something that will burn out within 6 months of serious useI'd recommend this to be honest
I've ran the 250 with no issues for the last 4 years and I've just purchased the 350 I've ran the esab 235 on demo it was nice but it didn't blow me away only advantage it had was it would run a 6010 welding rod but I don't run enough to warrant the need and the kempomats I have no experience with except the proper old school ones and they never let me down but were really never used much in anger to be honest![]()
Paton PSI 350 Pulse MIG Welder - 400V
Key Features 15MM maximum weld thickness on mild steel Industrial grade welding machine Pulse MIG, TIG & MMA 15KG maximum wire reel capacity Made in Europe 4 roll wire feeder 5 year warrantywww.weldingsuppliesdirect.co.uk
what was wrong with it?The Kempact we had at my previous employer was not very good, that's all I can say.
Have no experience with the Esab, but that would have to be a really bad machine for me to recommend the Kempact over it.
how is it on spray? does it do 1.2mm well on it? and what version you got ? the r or the a?Ran a Kem pact 323 for about 6-7 year never an issue and so nice to use . Only issue we ever had was one the lads put a pallet on the torch but that’s not the welders fault
what failed on it? and what was you welding on it?I have a Kempact RA 181a - single phase MIG.
It is not that good - I would not buy another one! We only use it with A18 0.8mm wire on mild steel exhaust fabrication.
Out of all the welding sets I have ever bought none of them have been back under warranty - this went back twice inthe first year. If it fails again - I will not bother to repair it. Shame as other Kemppi stuff I have bought has been good.
The esabs rebels have terrible reputions the Kemppis would be doing well too be beating them. Quite a few of the guys have the patons, @Tangledfeet had one till recently and I canny remember who else at this point in time.
The 320 is exactly the same cheap Chinese tosh inside.No personal experience of either, but I've heard enough bad stories about the Kempact RA series to make me want to steer clear. Heard plenty bad stories about the Rebels too, but most of them are single phase... the big boy 320 might be different? I dunno... glad it's not my money anyway.
I like both brands, they make some cracking machines (the older Kempomat migs we have are absolutely flawless, and I'd have an Aristomig) I just think both of those machines are built down to a price, and it shows.
what's your absolute requirements for a machine?
300 amps +?
Multiprocess inverter?
Compact? Or workshop use only?
Price? Or quality?
If it's getting as much use as you suggest, I'd be looking up a notch at Aristomigs, speedtecs, and offerings from EWM, Lorch, Fronius... double your current budget, but a lot more flexible for aluminium, stainless etc and made for proper work.
When your back our way Brad ill invite you and Hugh to one of my work shops and ill try to convert you to a patonBoth unreliable carp.
get a proper welder, like a Lorch.
