AnthonyExmouth
- Devon
I'll run 6mm from the CU to the socket. Mainy because I got no 4 mm in the workshop at the moment.Mild difference in cable price though. 4mm2 for 30 amp.
Even better.I'll run 6mm from the CU to the socket. Mainy because I got no 4 mm in the workshop at the moment.
I just got a flow meter for £11 feels like a no brainer?Ok, 2 more here.
1. How important is a flow meter?
2. I've read that for mild steel you need A15 rods but I also see A18 being advertised as Tig rods.
Where please, I need one.I just got a flow meter for £11 feels like a no brainer?
As in a spool?For mild steel mig wire works.
Yep, you can twist it together if it's too thin.As in a spool?
Not used it yet(waiting for gas) but looks fine...
Ooh, ouch plus another tenner to france.
Which one is best suited to Tig?Not used it yet(waiting for gas) but looks fine...
I’m also new to welding, but I can’t see why this wouldn’t work for any type of gas welding...it ultimately tells you how much gas is flowing...Which one is best suited to Tig?
I meant which one as in 0-14 or 0-25I’m also new to welding, but I can’t see why this wouldn’t work for any type of gas welding...it ultimately tells you how much gas is flowing...
I got the 0-25 so it would work for any use, I’m not sure why you’d bother with the 0-14...I meant which one as in 0-14 or 0-25
I imagine i'll be welding everything not nailed down, then I'll weld the nails.You will go through a 20l fairly quickly learning as can be addictive.
