Barking Mat
Cuddler of hedgehogs.
- France, Brittany.
Evening, nice quiet Saturday people?
Not bad. The wife has got a face like ten miles of bad road,apart from that,yes ishEvening, nice quiet Saturday people?
I will require a night cap of the good whisky.
But look on the bright side: The welded-on axle practically eliminates high-speed wheelbarrow accidents!Really chuffed I went to spin the wheel and realised it's a solid axel designed to run in bearings!
I now have a static flower planter.....
Made and fitted these brackets,Just in time for the rising river,been storing these in inaccessible places,time to make it easy,until I build a bigger workshop,unfortunately marine ply,outside for 3 years rots,what’s a practical plastic to use?View attachment 275729
Bit of a Rodney moment for me!But look on the bright side: The welded-on axle practically eliminates high-speed wheelbarrow accidents!![]()
There's an agricultural plastic used for sheep pens/pig sheds.
I've never used it - but it's been recommended on here a couple of times.
I can't remember what it's called.![]()
Are the trees holding the phone box, or viki-verki?@slim_boy_fat @dobbslc ,it’s close ,but not that close!were 3’above the highest flood I’ve experienced in 33years,which was last February.
I did post a few photos of that one last year.
Yes, but if you used the Teleport.If I evaporate it here, do you have condensation equipment to reverse the process?![]()
Can’t wait to hear it runNot all today, but over a few weekends, rebuilt a Perkins P3, new liners, crank, rings, bearings, all clearances to factory spec, put together and the first coat of Fordson Empire Blue on. Needs another coat before bolting the bits and pieces back on, the fitting the adapter plate and clutch and bolting back onto the body.
I was going to spray it but the castings are quite rough so a decent quality Tractol paint goes on nicely and can be worked well into the metal.
Looking forward to firing it up.
@KimB
I have an induction hob at home, if I use a cheap frying pan that's not 100% flat on the bottom the pan gets hot spots!Some weeks ago I dropped my Le Creuset frying pan on the stone floor in our kitchen -the result was a frying pan with the entire handle section of the casting broken away. This was closely followed by disbelief at the £££ cost of a replacement. So I bought a bog standard cast iron frying pan from Amazon for ££, reasoning that once it was seasoned it would be non-stick without any fancy coatings. however, the inside of this pan had a noticeable dome in the centre.
Resulting in one of my more unusual milling jobs....
Not really looking for a surface plate degree of flatness but needed to get an idea of what was doable with the dial gauge.
Blended the milling work with a 40 grit disc in the DA sander before seasoning it with some cooking oil and returning it to its natural environment.
My Granny had an old saucepan that burnt in one spot on the bottom - she blamed jam making in 1697 for it - sugar stuck and burnt. She had a Rayburn with flat hot plates on top - I noticed it wobbled slightly in 1990 - quick tap with a hammer in one spot . . . no more burning.I have an induction hob at home, if I use a cheap frying pan that's not 100% flat on the bottom the pan gets hot spots!
I suspect the bottom being flat is just as important as the inside?
My mum had a frying pan with a huge bulge in the bottom of it, she blamed me for putting water in it while it was hot. I'm pretty sure I'd never used it before but I do do that and it's never damaged any of my pans.My Granny had an old saucepan that burnt in one spot on the bottom - she blamed jam making in 1697 for it - sugar stuck and burnt. She had a Rayburn with flat hot plates on top - I noticed it wobbled slightly in 1990 - quick tap with a hammer in one spot . . . no more burning.
I still use the same saucepan![]()
Anyway when I did use it the rocking was really annoying (no idea how she put up with it) so I went outside and have it a thump with a rawhide hammer, good as new.
