No stand yet but it needs some kind of cast iron setup to look right I think.
How many different ones are there Brad? I’d like to stick one on the back of my Lorch MIG the same as on the ESAB 200i Caddy so I can easily swap the bottle from one machine to the other.I just need to order the right fitting now!
You want a rectus 21ka. I’m still undecided whether I want to put a male fitting or a female coupling on the back. In the past I’ve bought genuine Parker Rectus ‘Made in Germany’ fittings. From Tidyco.How many different ones are there Brad? I’d like to stick one on the back of my Lorch MIG the same as on the ESAB 200i Caddy so I can easily swap the bottle from one machine to the other.
I’ve always held off doing it as I’m not sure exactly which one I need.
Cheers Brad, I think I’ll see if I can find an inline male fitting that I can fit in the gas pipe rather than on the actual machine. Then I needn’t modify the Lorch casing, and if I leave a couple of feet of pipe attached to the machine it can hang off the bottle chain so I won’t have to reach down too far to plug in the gas.You want a rectus 21ka. I’m still undecided whether I want to put a male fitting or a female coupling on the back. In the past I’ve bought genuine Parker Rectus ‘Made in Germany’ fittings. From Tidyco.
Yeah get a rectus inline.Cheers Brad, I think I’ll see if I can find an inline male fitting that I can fit in the gas pipe rather than on the actual machine. Then I needn’t modify the Lorch casing, and if I leave a couple of feet of pipe attached to the machine it can hang off the bottle chain so I won’t have to reach down too far to plug in the gas.
Once again, nothing ground braking, but I've had my tig for over 7? years and the on / off switch has always been broken, not an issue, but half the time when I plug it in it trips out the breaker, which is in the neighbours workshop.
So finally got round to buying one, and its nearly fixed.View attachment 273288
Yep, true, I don't know if you can make out where some lout took a black marker pen and added some notes to remind them of what did what, been bugging me for years, spot of acetone and well it's not clean but cleaner.That's no good its all in foreign
Makes it more fun.That's no good its all in foreign
