- UK
Thanks to a forum member my enthusiasm in this is realighted. You know who you are
I rebuilt this Dexta engine a while ago, but now knowing a bit more, i've opened it up to check tolerances before I finish it off and send it
First off the bores - i've measured them and checked against the original book. These are the original liners (Original to me anyway), when i originally stripped it i took off the ridge at the top of the bores and put new piston rings on. The bores feel smooth, no nasty ridges etc.
It seems to be a massively tight tolerance in the handbook, and of course the liners have worn, but is this wear enough to warrant pushing the liners out, replacing and machining?
.First off the bores - i've measured them and checked against the original book. These are the original liners (Original to me anyway), when i originally stripped it i took off the ridge at the top of the bores and put new piston rings on. The bores feel smooth, no nasty ridges etc.
