Memmeddu
- Italia Sardegna
Fixed jaw stays inside the bench top area , and that's not ideal because your workpiece might not fit in your viceMemmeddu which vice/vise positon dont you likeI may learn something
i would suggest a support near to the edge of the blade for when you are grinding it you dont want that blade flexing a mm out when grinding the blade
measure first with a few blades and mark where the tip support needs to be then try the other blades out checking your marks
is the round bit going to move along the dovetailed flat? What about gib strip for adjustment
Rick and Morty is new to me. Interesting.True Level
Very nice
id build its own storage unit up and sit it on it
make it movable so when not needed it can be tucked out of the way then it wont get stored on top of it
make it also a store for things that need to be sharpened in there
if you want you could add its own top cover to protect it as well but thats your choice in the end
To alli meant this type of cover as ive seen it with tool and cutter grinders owners have built a nice unit and box cover on them
I am more than happy with the one ive built
- I blame @gaz1 who put me on to it [thanks again, mate
