Ashley Burton
- Northamptonhire
@James1979 Is it working well?
Spot on. There was a concern that he couldn’t knurl the pulley. There’s nothing to worry about there. When it was on air I could almost stop it on my hand with gloves on. This just rips metal off.@James1979 Is it working well?
WHY ???early last year I saw this on ebay, a educational toy for demonstrating how solar power works.
https://www.ebay.co.uk/itm/272425806540
and thought it might be a bit of fun to have it radio controlled using a "tank" speed controller, so each paddle is operated seperately.
https://www.ebay.co.uk/itm/143652897932
and using a single cell lipo battery and receiver for my other models I ended up with this
now thats a much better toy to play with, who'd have thought you could do doughnuts or even drift it like a car......think I should have done this much earlier only problem is now that I have another project to do in the next few years which will be to convert this to radio control and have it spinning on its centre axis.
as I bought one of these to build last summer.
one day I'll have to grow up and stop playing with toys.
I really like that, what was the donor tool?Not so much made , but finished off and assembled!
A member on here very kindly saw my post about intending to convert an air file to battery and turned up the two parts required. They arrived Yesterday and I finished them off and put it all together today. It was greatly appreciated, not easy being without a lathe when you’re used to one!!
It was a M12 3” cut off tool. Having bought it and had it for a while I really couldn’t see the use for it to be honest! Mates boy Sooth has one - he installs hygienic plastic on walls and they use them to rip sheets but outside that I really can’t work out what it does that a grinder doesn’t.I really like that, what was the donor tool?
Today we made a nasty looking engine block nice and pretty. 25year old engine now with a fresh lease of life.
Assuming you blasted it what did you go with water , dry vapour or bead etc.
I have some of these to clean up and only got a normal grit sand blasting cabinet at the moment.
Nice rig you have made for the camera.Thought I'd make my own visualiser (a downward pointing camera that would then project to the classroom screen, use them all the time at school) using my cheap £50 GoPro knock-off so I can record some lessons over the forthcoming period; I won't be teaching 'live' as the risk assessments and red tape are overwhelmingly disuasive and prohibitive.
The height and angles can be adjusted and there's some lead shot I found in the base so very stable. Made it out of aluminium so I broke out the Sherman 206P TIG welder over the weekend for some shameful welding - its been a while since I've done any alloy! The camera does create fisheye at such a close distance...
View attachment 268949 View attachment 268950 View attachment 268951
Looking at the distortion on screen, is it a 4k camera if so using it at 1080 will crop to a central part of the image and cut out some of the barrel distortion at the edge of the picture. You will have to move the camera a little higher but it might look better.
