A good tool in fusion when sketching is the line tool as it also allows you to do a radius as well. Vid below, draw line then for next segment hold down the left button and move and it will draw an arc.
Yeah I’ve seen John Saunders do things, especially with constraints, to get a sketch centred and stuff really really quick. Can’t bloody find the video now. You hold shift or Ctrl or something and it puts a line bang on the midpoint of another.
Project is excellent when drawing up something with components, You can select a component you have already done and the sketch projects onto the plane then you can alter if you wish before extruding. Use it all the timeConstraints are great especially the tangent but you have to click in the correct order
And the new sketch plane as it can be offset i also often use project
Project is excellent when drawing up something with components, You can select a component you have already done and the sketch projects onto the plane then you can alter if you wish before projecting. Use it all the time![]()
Can't believe it, that is a year I have been using Fusion now, just had the renewal in, £438 lighterWell worth it for me though
If you buy the three years on offer will that add onto your existing year?Should be an offer soon, a few weeks after I bought mine last year they sent an offer, half price
I think this time I will take them up on it but go for the 3 year deal, just hope I live long enough to take advantage of the 3 years![]()
Just the outer mate.. I need to be able to extrude the profile so it's thicker at the bottom than the top eventually but getting the profile is a start.Do you need it profiled or do you just want the outer profile
We already have the badge. https://www.ebay.com/itm/123561538057
The screen cast will help immensely.I’ll knock it out for you tomorrow if I get a chance. I’ll screencast it too.
Not got that far to even try yet mate...small steps.Extrude with taper
Don't really know how it works but that is unlikely. I do remember reading something about it but it was a while ago so I have forgotten.If you buy the three years on offer will that add onto your existing year?
Fairly obvious that..........NOT.Loft function extrudes stuff with a taper.
Or just press/pull and set taper angleLoft function extrudes stuff with a taper.
