redlig
- wiltshire uk
Thats the xmas drinks sorted then.
Arrived in the post today.
Been fed up with squinting at the smaller gauge I have so just bit the bullet and spent some dosh on a decent one. I seriously expect this one to last for decades, even if I don't. The scale is about 4" wide and it's supposedly accurate to 0.5 psi according to the test cert that came with it.
I like that !This followed me home. It’s a Walker Roll-a-Car floor jack rated at 5000lbs. You ratchet it up and ratchet it down. It’s a cool piece of kit!
I'm sure that will be a good read. Good luck for tomorrowChemo again tomorrow so something to keep my mind occupied
I like that !![]()
New reading glasses from the chemist or pound shop would have been cheaper
Precision/repeatably turning bar.What's it do/for?
What's it do/for?
The rollers support the material against the cutting forces, then when you retract the cutter lifts away from the material slightly so it doesn't mark/cut the material.
They're ideal for when you need to turn bar down to a precise size repeatably without worrying about deflection.
I'm considering mounting one in my CNC lathe for some parts I make, as they'll achieve a finish in a single pass without having to take multiple cuts and allowing for deflection.
