qwakers
- cornwall, united kingdom
Correct plus loop the green wire to earth so its permanently getting the start signal so it runs when you flick the main switch on.Mmmmm ,
I too have a working when striped out old tower computer power supply unit sitting on a shelf in my current mancupboard .
Just to clarify do you mean put all the outputs in parallel , + to + & - to- ve in a big terminal block then take out a single fused + & - ve to the burner panel that will then give you the required start 12 volt start up current plus a bit more in total so nothing gets overloaded & hot?
