seriously, i paraphrased from it above from memory, but i dont have it anymore, so dont ask for a copy![]()
240v via a chinese transformer 12v 30 amp unit
Same.
Although i think mine is a 20A
I have several, can't remember which one i've got connected ATM
It also runs some LED garden lights.
yeah was watching a u tube video and he ran LED light in his garage plus his diesel heater good set up it wasSame.
old pc power supply.how are you guys supplying 12 volts for use in the shed?
Same.
join a couple of the 12v busses together and any pc psu over 600w will do it. i know this, because that's what powers mine.
Correct plus loop the green wire to earth so its permanently getting the start signal so it runs when you flick the main switch on.Mmmmm ,
I too have a working when striped out old tower computer power supply unit sitting on a shelf in my current mancupboard .
Just to clarify do you mean put all the outputs in parallel , + to + & - to- ve in a big terminal block then take out a single fused + & - ve to the burner panel that will then give you the required start 12 volt start up current plus a bit more in total so nothing gets overloaded & hot?
Not necessary. Yellow wires connect in parallel and green wire on main board connector to any black wire.have you got pics and a wiring diagram ?
